we are using Zabbix version 4.2 combine with Twilio SMS alerts external scripts.
All works fine according to the severity level.
I would like to know if there is a possible way to receive detailed Alert information and not just generalize text. (e.g. there is a problem please check Zabbix dashboard)
Thanks, heaps.
in Zabbix (Action):
cd /usr/lib/zabbix/alertscripts/
php critical-sms.php
in ExternalScript (folder):
Thanks, heaps.
in Zabbix (Action):
<?php
/* Send an SMS using Twilio. You can run this file 3 different ways:
* 1. Save it as sendnotifications.php and at the command line, run
* php sendnotifications.php
* 2. Upload it to a web host and load mywebhost.com/sendnotifications.php
* in a web browser.
* 3. Download a local server like WAMP, MAMP or XAMPP. Point the web root
* directory to the folder containing this file, and load
* localhost:8888/sendnotifications.php in a web browser.
// Step 1: Get the Twilio-PHP library from twilio.com/docs/libraries/php,
// following the instructions to install it with Composer.
require_once "vendor/autoload.php";
use Twilio\Rest\Client;
// Step 2: set our AccountSid and AuthToken from https://twilio.com/console
$AccountSid = "xxxx";
$AuthToken = "xxxx";
// Step 3: instantiate a new Twilio Rest Client
$client = new Client($AccountSid, $AuthToken);
// Step 4: make an array of people we know, to send them a message.
// Feel free to change/add your own phone number and name here.
$people = array(
// "+1234" => "James",
"+1234" => "James",
"+1234" => "James",
"+1234" => "James",
"+1234" => "James",
$now = time();
$now = date('r', $now);
// Step 5: Loop over all our friends. $number is a phone number above, and
// $name is the name next to it
foreach ($people as $number => $name) {
$sms = $client->account->messages->create(
// the number we are sending to - Any phone number
$number,
array(
// Step 6: Change the 'From' number below to be a valid Twilio number
// that you've purchased
'from' => "+xxxxxxx",
// the sms body
'body' => "PROBLEM. Hi $name,\nthere is Zabbix alert with severity of:\nCritical ; High.\ncheck Zabbix dashboard or mailbox. event was occurred on $now"
// Display a confirmation message on the screen
echo "Sent message to $name";
