I have problems with Configuration->IT Services
  • debora
    • Jan 2006
    • 75
    I need your help for this because i have monitoring many servers, where is the error look:
    Error in query [select count(*) as cnt from services_links where servicedownid= and soft=0] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'and soft=0' at line 1]
    Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/zabbix/public_html/include/db.inc.php on line 174
    [Trigger added]
    SQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'on,0,off,99)' at line 1
    Query: insert into services (name,status,triggerid,algorithm,showsla,goodsla,s ortorder) values ('Version of zabbix_agent(d) was changed on {HOSTNAME}',0,12264,on,0,off,99)
    SQL error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '7,0)' at line 1
    Query: insert into services_links (servicedownid,serviceupid,soft) values (,7,0)
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please wait for 1.1.2. It is already fixed.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • debora
      • Jan 2006
      • 75
      But any thing by now? because i can't wait for release next version, i'm monitoring servers in production in a enterprise
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Use of open source software without purchasing a commercial support suggests that you can wait We plan to release 1.1.2 within two weeks.
        Alexei Vladishev
        My Twitter
        • debora
          • Jan 2006
          • 75
          Thanks Alexei i waiting for this release next version
          • elp
            • Aug 2006
            IT - Services
            Error: "Error in query [select count(*) as cnt from..."
            Change include/services.inc.php line 58:
            old line: $sql="select count(*) as cnt from services_links where servicedownid=$serviceid and soft=0";
            correct line: $sql="select count(*) as cnt from services_links where servicedownid='$serviceid' and soft=0";
            and
            Error: "SQL error: You have an error in your SQL syntax..."
            Change include/services.inc.php line 27
            old line: " values (".zbx_dbstr($name).",0,$triggerid,$algorithm,$sho wsla,$goodsla,$sortorder)";
            correct line: " values (".zbx_dbstr($name).",0,$triggerid,'$algorithm',$s howsla,'$goodsla',$sortorder)";
            good luck
            • debora
              • Jan 2006
              • 75
              Very Thanks now work fine
