Email notification for Recovery
  • zabbix.user05
    • Aug 2014
    Need help, just setup the zabbix 2.2 and testing the email notification, however, I can only received the PROBLEM notification but RECOVERY don't have even the "Recovery message" is checked.
    Any idea to fix?
  • Smersh
    • Jul 2013
    • 49
    Conditions are used by zabbix for Default message. For Recovery message are used the reverse conditions.
    Summary: delete [Trigger value = OK] condition.
    • zabbix.user05
      • Aug 2014
      Hi Smersh,
      Thank you for the reply,
      I deleted this condition [Trigger value = OK] but still the same, unable to receive Recovery message.
      checked on Monitoring --> Events, status was "sent".
      Tried many ways without success. Any workaround?
      • Smersh
        • Jul 2013
        • 49
        You probably mean Monitoring -> Dashboard -> Last Issues - > Action column. See if there is "OK" value in 'Action' column of Monitoring -> Events table in the same row, where 'Status' value is also "OK".
        And p.s. Could you show the trigger expression that causes mentioned action?
