Zabbix_sender doesn't work
  • ssoupirot
    • Aug 2014
    i Created an Item with the following details
    type = Zabbix Trapper
    Key = trap
    type of information = Numeric (unsigned)
    Data type = Decimal
    From one of my server i'm trying to send data to this item via the following syntax
    zabbix_sender -z SRV0374 -p 10051 -s SRV0420 -k trap -i c:\scripts\logsuperview.txt -vv
    and i obtain
    zabbix_sender [2728]: Warning: [line 1] 'Key' required
    sending failed.
    the file logsuperview.txt contains only the number 1
    i tried to send a number with -o "1" but it didn't work too.
    zabbix_sender [5632]: DEBUG: answer [
    { "response":"success", "info":"processed: 0; failed: 1; total: 1; seconds spent: 0.000028"}
    info from server: "processed: 0; failed: 1; total: 1; seconds spent: 0.000028"
    sent: 1; skipped: 0; total: 1
    Do i miss something ??
  • jan.garaj
    • Jan 2010
    • 506
    -i, --input-file <inputfile>
        Load values from input file. Specify - for standard input. Each line of file contains whitespace delimited: <hostname> <key> <value>. Specify - in <hostname> to use hostname from configuration file or --host argument. All entries are sent in a sequential order top-down.
    => don't use key (-k trap) as parameter, but specify key in your input file
    • ssoupirot
      • Aug 2014
      Test done but i still have the problem
      i tried the following command line.
      C:\Scripts>zabbix_sender -z srv0374 -p 10051 -s SRV0420 -i c:\scripts\logsuperview.txt -vv
      zabbix_sender [6896]: Warning: [line 1] 'Key' required
      Sending failed.
      The content of my file logsuperview.txt is
      SRV0420 trap 4
      So this means that
      hostname = SRV0420
      Key = trap
      value = 4
