After much struggling and a lot of help from #Zaabix IRC
Active Checks on W32 Agent seems to work.
But some things still bug me,
First When I edit the conf file and use
DisableActive= OR
RefreshActiveChecks=
and run zabbixw32 check-config I get "unknown option"
I use w32 agent 1.1
I understand that active checks are enabled by default,
But I do try to change the refresh time... 2 minuts for some services is just too long....
Any Ideas ?
DisableActive= OR
I use w32 agent 1.1
Any Ideas ?
