EventLog - What's the regexp is used for?
  • registration_is_lame
    • Nov 2007
    • 148
    I can't find a example for eventlog with regexp. name,<regexp> - what is the regexp trying to match? is the regexp used to match the Event ID general tab data?
    eventlog[name,<regexp>,<severity>,<source>,<eventid>,<maxli nes>,<mode>]
    name - name of event log
    regexp - regular expression describing the required pattern
    or is the regexp used here to something else?
    Event ID: 12345
    Example of a general tab data is
    "The Desktop Window Manager has exited with code (0xd00002fe)"
    And how should I use the regexp.
    Is it like
    eventlog[Application,(.*1234.*),,Information,,123]
    or
    eventlog[Application,regexp(.*1234.*),,Information,,123]
  • gofree
    • Dec 2017
    • 400
    Id use something like
    eventlog[Application,,Information,,12345,,skip]
    this will search for event ID 12345 from Application log with severity Information and only foe new occuring events ( skip ) - I think if you have the event ID, name of teh log, severity - even better if you know source you dont need to use regexp ( maybe for special occasions where the event ID is not unique)
    alternativelly
    eventlog[Application,.*12345.*,Information,,,,skip] - will search for log events with string 12345 - remaining option apply as above
    in general your second guess will now work
      • Nov 2007
      • 148
      Okay. I tested it and the regexp is really there to match the event viewer general tab (description) data. I want to figure if we can split the lines using preprocessing. The general tab has 2 lines of data. But I don't want the first line logged into zabbix. The eventlog[Application,.*12345.*,Information,,,,skip] matches the second line.
