Looking for a piece of Javascript code to preprocessing values
  • mbuyukkarakas
    • Aug 2014
    • 49
    Dear all,
    I'm trying to get values with curl from my Windows servers. Everything is fine but curl returns a value like ' 0,014582 '
    Eventually zabbix doesnt recognize this value as numeric (float) or numeric (unsigned), only as string.
    As you can guess, It doesnt help to me to draw a graph so I need to replace the comma to dot with value preprocessing. It seems that a piece of javascript code will be fine to do that. But my knowledge about Javascript is not enough to do that.
    Can anybody help me to convert 0,014582 to 0.014582 with Javascript ?
    Thank you. Regards.
    Mehmet
    PS : Changing local settings of Windows is not an option.
  • Atsushi
    • Aug 2013
    • 2028
    ex.
    var result = value.replace(',','.');
    return result;
    • mbuyukkarakas
      • Aug 2014
      • 49
      Atsushi, you saved my life. I really appreciate your help. It worked perfectly. Thank you so much.
      Mehmet
