Trigger does not change from "Unknown"
  • ABC Loud
    • Oct 2019
    Good Morning,
    If you have any knowledge about Zabbix Trigger Status, please let us know.
    [Issue]
    We use Zabbix 3.1.5 and currently there is an issue of some Trigger on Windows server does not change from "Unknown" stats.
    Details are Trigger of Memory 95% is Unknown when a cursor is moved to Trigger Status.
    Other Triggers such as Process and CPU are enabled with out any problem.
    We have checked the following action but the issue still remains.
    ・Clicked and changed the Trigger to "Disabled" and click again.
    The status changed "Unknown" -> "Disabled" -> "Unknown".
    ・Rebooted a server which use for Zabbix
    Best Regards,
    ABC
