How to retreat a response from http:// site and create a trigger for the return value
  • scuba
    • Jun 2018
    • 16
    I need to retrieve the status code from a web site and make a trigger for the return value which is;
    http://192.168.10.25/xxx/public?cmd=status the value from the site is either 0 or 1 , so how can i make web scenario to read this code please ?
    Thx in advance.
  • Mike2K
    • Oct 2018
    • 60
    When creating the web scenario, you''ll get to the 'steps' part. There you can have it search for a "required string" which, in your case, would be the 0 or 1...
    • 1berto
      • Sep 2018
      • 182
      Do you need to check the response from a host monitored by zabbix? Or from the zabbix server itself? Mike's answer is correct and is the way to go. But if you can't use it you can create an external check with a command or script that get the status.
      • scuba
        scuba commented
        No it's not monitored by zabbix , but it's reachable from a host monitored by zabbix.
