monitor storage size for NFS
  • ytao
    • Aug 2019
    I am using Zabbix 4.2 and applied "Template OS Linux" to a host. The "Mounted filesystem discovery" does find all local mounted filesystem, but does not discover the NFS ones, e.g. /ILdata/arc_data05. If "vfs.fs.discovery" doesn't find the NFS, what other key or template could be used for NFS?
    Thanks.
    $ df
    Filesystem 1K-blocks Used Available Use% Mounted on
    /dev/mapper/rhel-root 47158788 3387144 43771644 8% /
    devtmpfs 3992860 0 3992860 0% /dev
    tmpfs 4004776 0 4004776 0% /dev/shm
    tmpfs 4004776 410500 3594276 11% /run
    tmpfs 4004776 0 4004776 0% /sys/fs/cgroup
    /dev/sda1 520876 216484 304392 42% /boot
    /dev/mapper/rhel-home 31441920 33456 31408464 1% /home
    /dev/mapper/rhel-var 20961280 3332136 17629144 16% /var
    /dev/mapper/rhel-tmp 4708352 76396 4631956 2% /tmp
    10.34.128.90:/dev2_ildata05 199229440 47504256 151725184 24% /ILdata/arc_data05
    10.34.128.130:/DRMDT 199229440 32640 199196800 1% /ILdata/doctrackr
    10.34.128.90:/dev2_master 19922944 5106304 14816640 26% /ILdata/master
    10.34.128.90:/dev2_ildata04 99614720 74266240 25348480 75% /ILdata/arc_data04
    10.34.128.91:/dev2_ildata01 209715200 124861632 84853568 60% /ILdata/arc_data01
    10.34.128.91:/dev2_ildata06 199229440 55779072 143450368 28% /ILdata/arc_data06
    10.34.128.91:/dev2_cgl 24903680 3086464 21817216 13% /ILdata/cgl_share
    10.34.128.90:/dev2_ildata01_emea 49807360 3768448 46038912 8% /ILdata/arc_EMEA_data01
    10.34.128.91:/dev2_ildata02 209715200 129802560 79912640 62% /ILdata/arc_data02
    10.34.128.90:/dev2_ildata03 209715200 190262272 19452928 91% /ILdata/arc_data03
    tmpfs 800956 0 800956 0% /run/user/1463817875
  • 1berto
    • Sep 2018
    • 182
    If you can create a script you can use an UserParameter, not?
    Those volumes appear on df command? If they do you can also try the system.run key (on the server).
    • Hamardaban
      • May 2019
      • 2714
      pay attention to “Filters tab”
      • ytao
        • Aug 2019
        yeah, I ended up with script and UserParameter. Not sure how to use "Filters" tab since "@File systems for discovery" doesn't discover the "NFS" mount points. I am not sure if I misunderstood something.
        • kloczek
          • Jun 2006
          • 1771
          No you don't need UserParameter.
          Standard zabbix "Template OS Linux" template uses "@File systems for discovery" filter. By default that filter contains "^(btrfs|ext2|ext3|ext4|reiser|xfs|ffs|ufs|jfs|jfs 2|vxfs|hfs|apfs|refs|ntfs|fat32|zfs)$ [Result is TRUE]"
          You must have removed that filter in you template or you template is using different filter of that regexp (Adminisstration->General->Regular expressions-> File systems for discovery) has different definition than above.
          • ytao
            ytao commented
            Thanks. However, the discovered filesystems don't seem to include nfs.
