Remote commands
  • bbrendon
    • Sep 2005
    • 873
    Remote commands
    I'm running 1.1 of Zabbix and I just spent about two hours trying to get remote commands to run on a linux system with NO luck.
    When running
    zabbix_agentd -p
    I get:
    system.run[echo test]                         [t|test]
    Script command:
    cli.flower:/tmp/myscr.sh
    where "cli.flower" is the host as zabbix knows it.
    I also created another action with:
    grp1#/tmp/myscr.sh
    ...this yields nothing as well.
    I also tried with and without the condition:
    Trigger value = "ON"
    I have debuglevel set to 4, and none of the remote commands I enter into the actions even show up in the agent logfile. I have a script that is executable by all in /tmp that creates a tmp file in /tmp and nothing is appearing as well.
    I'm stumpted!!!
    Unofficial Zabbix Expert
    Blog, Corporate Site
  • dantheman
    • May 2006
    • 209
    Do you have
    EnableRemoteCommands=1
    in your agent's config file?
    I had the same issue this morning and after I uncommented that line, restarted the agent, then it worked.
    • bbrendon
      • Sep 2005
      • 873
      Thanks for the reply. Yes. I have EnableRemoteCommands=1 in the agent config file.
      I thought it might have something to do with the "." in the hostname, but i renamed it and removed the "." ... same results.
