Is it possible to add multiple subnets to a single discovery scan? Also How do I format a subnet that goes from say 10.10.32.1 to 10.10.33.254?
Help adding multiple subnets
According to the docs (https://www.zabbix.com/documentation...discovery/rule) it looks like you can, maybe with this in the 'IP Range' field...
10.10.32.1 - 254, 10.10.33.1-254
or
10.10.32-33.1-254
I hope this helps! -
Yes. Something like: 10.10.32.1-10.10.33.254
Or you can try 10.10.32-33.1-254
Use dash (-) for ranges. In my zabbix installation i have something like:
10.10-15.1-20.253-254Comment
