DB Monitor cannot connect to Oracle
  • cqxiak
    • Mar 2014
    Database monitoring is not working for oracle DB. once item configured, I can found the request to oracle via odbc just hanged at below step:
    [ODBC][15921][1410415995.302177][SQLConnect.c][3727]
    Entry:
    Connection = 0x11561e0
    Server Name = [ORA_T][length = 5 (SQL_NTS)]
    User Name = [][length = 0 (SQL_NTS)]
    Authentication = [][length = 0 (SQL_NTS)]
    UNICODE Using encoding ASCII 'UTF-8' and UNICODE 'UCS-2LE'
    and connect to oracle via isql is working well. anyone have related experience on this? thanks very much
  • syndeysider
    • Oct 2013
    • 115
    DBforBix
    Although this doesn't answer your question directly, there is a workaround.
    Check out : http://www.smartmarmot.com/product/dbforbix/
    I switched to the above as I didn't want to pay the license fee for the Oracle DSN Driver and didn't want to pollute my Zabbix Infrastructure with the Oracle client + java etc.
    DBforBIX works great and I've handed over the dboracle.query file to my DBA's who are in charge of creating items/triggers for the various Databases they have.
    • cqxiak
      • Mar 2014
      Thanks all. I have fixed this issue. maybe not the correct one, but it works.
      this issue was found when using UnixODBC with version 2.3.2, but version 2.3.0 is working well.
      • akbar415
        • May 2015
        • 119
        How you configure your unixODBC to connect to oracle ?
        I can make this by set the environment variable $TWO_TASK, but is there another way?
