Dell N4032F switch template?
  • jhdore
    • Oct 2019
    Hi all,
    My network is mostly Juniper stuff which I'm monitoring very nicely with the Juniper templates, but in our VM infrastructure we have four crappy Dell N4032F SFP+ switches in two stacks of two. I'd like to be able to monitor these in the same way as my Junipers, but can't figure out which template to use. Any ideas? They're not the Force10-based switches if that makes any difference. Our Zabbix is version 4.0.13.
    Cheers!
    James
  • bercerobry
    • Oct 2019
    • 17
    Dig the manufacturer's snmp oid's for these switches and create a template out from those oid that you want to monitor.
    There are tons of existing templates and you can copy cat them and modify it to suit your dell switches.
    Discovery of ether interfaces might be a little tricky though.
    • jhdore
      • Oct 2019
      Ok, sounds doable - to do that, which bits of the documentation should I look at first?
