I've been following this guide to creating a custom item to monitor my SIP trunks:
I'm running Zabbix server 2.2.5 on FreeBSD 10.
The agent is on a CentOS 5 based system with version 2.2.6.
Basically what I did was per the guide, add this line to the agentd config file:
Then using the key:
where "nnnnnnnnn" is the username in the item field I should be able to get a text output in Zabbix.
Unfortunately this is not the case and no data is being returned?
If I run the command on it's own the output given is:
If I run the command embedded in the agent using:
The result is:
So for the agent side everything is fine! ...it seems.
Looking at the Zabbix server however, the item is shown as being "active" and checks are being run.
The only issue is that there is no data in the "Last value" field??
Item settings are as follows:
Type: Zabbix agent
Key: <described above>
Host interface: IP of host with agent port
Type if information: Text
Update interval: 30 secs
Application: <created a new app called Trunks>
Enabled: checked
I'm really not sure what the issue is here? Also since I've just been debugging the MySQL application monitor which is now working properly. It just needed a little "fudging" of keyname to name put in the agent config.
I also tried enabled debug mode of logging but unfortunately that didn't help either as I was unable to see what the server was doing.
Could anyone help out?
Thanks.
UserParameter=asterisk.sip[*],asterisk -r -x 'sip show registry'|grep "$1 "|cut -c 71-91|tr -d "\n "
asterisk.sip[nnnnnnnnn]
Registered
zabbix_agentd -t <key>
[t|Registered]
Type: Zabbix agent
Enabled: checked
Thanks.
