DBforBIX and Zabbix 2.2
  • Serg10
    • Jun 2014
    We are trying to use DBforBIX with Zabbix 2.2. It used to work fine with Zabbix 2.0 but now fails : DBforBIX log says SQL collect is fine and data is transmitted to Zabbix. Zabbix log shows the DBforBIX messages but nothing happens next (items are not updated).
    Two questions:
    (1) Does anyone know if DBforBIX works with Zabbix 2.2 ?
    (2) DBforBIX uses "<req><host>...</data></req>" to communicate data to Zabbix and not JSON. Is this message format still supported by Zabbix 2.2 ?
    Regards,
    Serge
  • Smoke
    • Jul 2014
    • 29
    I can confirm that it does work with zabbix 2.2, i was using it with 2.2.1 up to 2.2.6 and now upgraded to 2.4.0 and still working.
    I am using it for MySQL as well as for Oracle DBs.
