Although there is a page in the documentation with many examples, I am still struggling with the whole concept of trigger flags and switches. For example, I have a self-made test script, say it returns some float between 0.0 and 0.5. The trigger should pick up the value between 0.1 and 0.3.
{SOMEHOST:check.process_CPU_java.last()}>0 and {SOMEHOST:check.process_CPU_java.last()}<0.3
Yet it tells me this function is not supported - which function is it and what does it support?
Another one, here some script should return True or False, yet it is unsupported again
{SOMEHOST:check.random_state_one.str(False)}=1
Any good hint or advice is appreciated.
thanks in advance,
thanks in advance,
