Scripted maintenance period does not properly show in maintenance list
  • waardd
    • Aug 2014
    • 82
    When we create a maintenance period with a script (see further down for the script) the periods are not showing in the right way in the list.
    See picture below, it shows several pages but all are empty
    I am wondering if its a bug in Zabbix where we for instance use characters that are forbidden or something.... or is it the json calls in the script?
    The script we use is as following:
    #!/bin/bash
    #Script Name    : zabbix_json_tst.sh
    #Description    : Set the maintenance period for a zabbix host-group
    #Author         : Danny de Waard
    #Email          : [email protected]
    # functions
    function_help () {
            echo -e "The parameters for this tool are:\n"
            echo "-u or --user      username for zabbix"
            echo "-p or --password  password for the zabbix user"
            echo "-g or --group     zabbix hostgroup to set maintenance for"
            echo "-n or --name      Name for the maintenance period (no spaces allowed or quoted)"
            echo "-s or --start     starttime-date in quoted yyyy-mm-dd hh:mm:ss (default is starttime/date of script)"
            echo "-d or --duration  duration of maintenance period in seconds"
            echo "                  300 seconds is 5 minutes"
            echo "                  1800 seconds is 30 minutes"
            echo "                  3600 seconds is 1 hour"
            echo "                  default is 3600 seconds"
    function_GetAutorization () {
    #Requeststring for Authorization key
    ReqAuth='{"jsonrpc": "2.0",
                    "method": "user.login",
                    "params": {
                            "password": "'"$passwd"'",
                            "user": "'"$usr"'"
                    "id": 0
    # get authorization string
    result=`curl -i -H "Content-Type:application/json-rpc" -X POST -d "$ReqAuth" "$url"`
    Auth=`echo $result | awk -F"\"" '{print $8}'`
    echo "The autorization string is: $Auth"
    function_GetGroupId () {
    #Requeststring for hostgroupid
    ReqGrId='{"jsonrpc": "2.0",
                    "method": "hostgroup.get",
                    "params":{
                            "filter":{
                                    "name":["'"$hgroup"'"]
                    "auth": "'"$Auth"'",
                    "id": 1
    # get groupid string
    result=`curl -i -H "Content-Type:application/json-rpc" -X POST -d "$ReqGrId" "$url"`
    GroupId=`echo $result  | awk -F"\"" '{print $10}'`
    echo "GroupId for ${hgroup} is ${GroupId}."
    function_SetMaintenance () {
    ReqSetMaint='{"jsonrpc": "2.0",
                    "method":"maintenance.create",
                    "params": {
                            "name":"'"$maintname"' - '"$start"'",
                            "active_since":"'"$start"'",
                            "active_till":"'"$end"'",
                            "groupids":[
                                    "'"$GroupId"'"
                            "timeperiods": [
                                            "timeperiod_type": 0,
                                            "start_date": "'"$start"'",
                                            "period": '"$duration"'
                            "auth":"'"$Auth"'",
                            "id":1}'
    result=`curl -i -H "Content-Type:application/json-rpc" -X POST -d "$ReqSetMaint" "$url"`
    MaintId=`echo $result | awk -F"\"" '{print $10}'`
    # Error check
    re='^[0-9]+$'
    if ! [[ $MaintId =~ $re ]] ; then
            echo -e "\nWatch it!\n"
            echo -e "Setting the maintenance period has failed. Check the parameters\n"
            function_help
            exit 1
    fi
    echo "MaintenanceId $MaintId is set."
    # default values
    # maintname="TestMaintenance"
    start=`date +%s`
    end=$((start+duration))
    duration=3600
    url="http://lsrv2289.linux.rabobank.nl/zabbix/api_jsonrpc.php"
    # processing the parameters
    # Check if there are any paramaters
    if [ $# -eq 0 ]
      then
      echo -e "No arguments supplied\n"
      function_help
      exit
    fi
    while [ "$1" != "" ]; do
            case $1 in
                    -u |--user )            shift
                                            usr=$1
                    -p | --password )       shift
                                            passwd=$1
                    -g | --group )          shift
                                            hgroup=$1
                    -n | --name )           shift
                                            maintname=$1
                    -d | --duration )       shift
                                            duration=$1
                    -s | --start )          shift
                                            start=`date -d "${1}" +%s`
                    -h | --help )           function_help
                                            exit
                    * )                     echo "You really got no clue..."
            esac
            shift
    done
    # Setting end time
    # setting the maintenance period
    function_GetGroupId
