Is it possible to monitor through zabbix what's inside zabbix-java-gateway?
  • bartosz.piekarski
    • Oct 2019
    In my setup I am monitoring some java applications. Significant amount and everything was fine till yesterday when java gateway stopped responding. I am suprised that zabbix-java-gateway is not monitoring itself as zabbix agent is monitoring zabbix-server. I was trying to connect to the port on which it is listening but I receive error:
    java.io.IOException: Failed to retrieve RMIServer stub: javax.naming.CommunicationException [Root exception is java.rmi.ConnectIOException: non-JRMP server at remote endpoint]
    I was trying to add:
    -Dcom.sun.management.jmxremote.rmi.port=12346
    and
    -Dcom.zabbix.jmxremote.rmi.port=12346
    Parameters but it didn't help.
    Does anyone succeed in setting up this monitoring?
    Thanks in advance.
  • Hernandes Martins
    • Apr 2011
    • 901
    hi,
    The first option, create a simple item and triggers to test port and another simple configs, add trigger no data when not receive data.
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • bartosz.piekarski
      • Oct 2019
      I have no delay with knowing if Zabbix Java Gateway is not responding, as this appears as all my JMXes are unreachable and as result i have hundreds of triggers. I would like to monitori Zabbix Java Gateway itself and have triggers ready on its metrics and maybe resize it if its not stable anymore.
      • bartosz.piekarski
        • Oct 2019
        I got it covered, my zabbix java gateway was missing some parameters to enable and by adding:
        -Dcom.sun.management.jmxremote.authenticate=false
        -Dcom.sun.management.jmxremote.ssl=false
        -Dcom.sun.management.jmxremote.port=12345
        -Dcom.sun.management.jmxremote.rmi.port=12345
        I was able to start gathering JMX details from it.
