Disable triggers for specific host groups
  • thuizt
    • Apr 2012
    We have several host groups that we like to monitor so we have diagnostic data to troubleshoot.
    For those group we don't want the triggers in the template to activate as they are cluttering our dashboards and as we are not responding to those triggers anyway we like to get rid of them.
    Can this be achieved in a simple way ?
    The only option we know of by know is opening every host config in the specific groups to disable the triggers. There must be a better way to achieve this.
  • Hernandes Martins
    • Apr 2011
    • 901
    Native option not, just by host. Use Zabbix API to disable triggers in mass is as great option.
    __
    Att.
    Skype: hernandss
    Telegram: @MrHernandes
    Español
    Português
    • pcn
      • Mar 2023
      Hello, I am new to Zabbix, can you provide a little example about how to do this?
