ifspeed value use a 32bit counter, but to TenGigabitEthernet interface, it can't get the right value, how to change the counter to 64bit, thanks.
ifspeed counter
i want get the ifSpeed value, not the traffic of the interface.
i'm monitoring the traffic of the interface on switches, because speed of the interface may be different, so i set the alarm threshold to 80% of the max speed of a interface. so i need the snmp ifSpeed value. but to TenGigabitEthernet interface, ifSpeed use a 32-bit counter, it doesn't work.
now I specify threshold to 8G instead.Comment
