Eventlog not trigger when value contains certain text
  • rodek
    • Nov 2019
    Hi all,
    I am monitoring if a certain eventlog comes by and trigger when it does. This al works but now i want it NOT to be triggerd if the value contains certain text.
    Anyone got some ideas?
  • valentins.grins
    • Nov 2019
    • 38
    I don't see your trigger expression so can't propose the exact solution but you may look for the following: use logical operator "and" within trigger expression and function str(), please check supported trigger functions for this. If str() don't find the string in your value then it returns 0.
    • rodek
      rodek commented
      Thanks for your reply. For now i have the below trigger for creations of scheduled tasks. I want exclude the logs for certain scheduled tasks.
      ({Test Rob:eventlog[System,,,,106,,skip].logeventid(106)}=1 and {Test Rob:eventlog[System,,,,106,,skip].nodata(120)}=0)
  • valentins.grins
    • Nov 2019
    • 38
    Hello, can you show the sample event log?
    Sorry there must be some confusion, what do you mean with "exclude the logs"?
    • rodek
      rodek commented
      See attached file (event.png). The general tab is the value that Zabbix will get as value.
  • rodek
    • Nov 2019
    Got it to work. I tested it with what valentins.grins mentioned and it worked. I added "and {Template:eventlog[logname,,,,106,,skip].regexp(text)}=0" to the trigger.
