nodata false errors
  • 1berto
    • Sep 2018
    • 182
    nodata false errors
    I have seen a lot of people with the same error, but can't find a answer.
    I'm using the following trigger:
    {template:agent.ping.max(#3)}=0 or {template:agent.ping.nodata(15m)}=1
    and having a lot of triggers fired. But when i try the hosts with zabbix_get i receive a correct value (so there is data).
    I also have a duplicate zabbix structure (dual servers, proxies, etc), each active agent send the the data to two proxies (one in each zabbix site), and the error occurs just in one of the sites.
    I have double checked firewalls, network, etc. As i said when i use zabbix_get i read a value.
    Any clues?
