Is there any way to get SLA report from Zabbix?
  • Sowmiya
    • Nov 2019
    I am trying to figure out if there's any report ( about the alerts and how fast it was rectified) that can be generated and sent to manager.
    Normally to find out the missed SLA's and also for performance review.
  • jong21
    • Nov 2019
    Originally posted by splitek
    No, not directly from Zabbix. You can use API to get SLA (if you get values you can use it in any tool):
    Or you can use something like Grafana (with or without grafana-reporter).
    Or if you know DB structure you can connect some reporting tool and build reports there.
    I am using Grafana with grafana reporter
