Howto detect that an "active" agent is down?
  • ulff
    • Aug 2014
    I have a scenario with a Zabbix agent behind a firewall. The agent pushes data to zabbix server, all items are active. What if the agent crashes or the host goes down. What is the best strategy/technique to detect this in the Zabbix server?
  • coreychristian
    • Jun 2012
    • 159
    The best way I have found is to setup nodata on your triggers for active items. If the entire server is active you may not want to enable nodata on all of the triggers, but at least one-two, or one massive no data that looks at all of your items
    • ulff
      • Aug 2014
      Thank you! I made an agent.ping item as "agent (active)", and setup a nodata trigger on it. And it works very well.
