Problem with active checks and zabbix proxy
  • rolfrolf
    • Oct 2019
    • 17
    ive got a problem with the active checks and the zabbix proxy. i get this line in the log file of the agent
    active checks configuration recieved from ... started to fail ZBX_TCP_READ() or sometimed in the brackets (SSL_read()) timed out
    ServerActive configuration is right its the ip of the proxy.
    When i connect the agent directly to the server without the proxy between the active checks run perfectly.
    Sidenote the proxy is in passive mode.
    Hope some of you can help me.
