Can anyone help me find a way to monitor the number of RPC calls on my echange server?
Exchange 2010 RPC monitoring
RDP to your Exchange server (Or have an Admin do it), pop a DOS box and type this command:
typeperf -qx > perfcounter.txt
That will create a text list of all the PerfMon counters that you can monitor.
Find the one that you want, then enter it into Zabbix as a perfcounter.
And it would look something similar to this. Doesn't have to be Active agent.
These 2 screenshots are the same thing, just different views. The second one shows the full syntax so you can see the entire key, with a 60 second update interval
