How to discovery IS-IS Adjacency Groups from Nokia 7750 SR?
  • wyang
    • Mar 2016
    • 93
    Nokia 7750 SR supports multiple instances of IS-IS. We need to monitor the status of adjacency groups of IS-IS instances. The status of each adjacency can be derived from the IS-IS adjacency table in the IS-IS MIB, where each OID has three levels of indices: IS-IS instance index, circuit index and adjacency index.
    How to set up a discovery rule or discovery rules to discover each IS-IS adjacency?
    IS-IS adjacency table in the IS-IS MIB:
    isisISAdjTable OBJECT-TYPE
    SYNTAX SEQUENCE OF IsisISAdjEntry
    MAX-ACCESS not-accessible
    STATUS current
    DESCRIPTION
    "The table of adjacencies to Intermediate Systems."
    ::= { isisISAdj 1 }
    isisISAdjEntry OBJECT-TYPE
    SYNTAX IsisISAdjEntry
    STATUS current
    DESCRIPTION
    "Each entry corresponds to one adjacency to an
    Intermediate System on this system."
    INDEX { isisSysInstance,
    isisCircIndex,
    isisISAdjIndex }
    ::= { isisISAdjTable 1 }
    Any advice would be much appreciated.
  • wyang
    • Mar 2016
    • 93
    Example of snmpwalk results showing 3 levels of indices
    $ snmpwalk -v2c -cplebeian 10.200.1.10 ISIS-MIB::isisSysType
    ISIS-MIB::isisSysType.0 = INTEGER: level2IS(2)
    ISIS-MIB::isisSysType.2 = INTEGER: level2IS(2)
    $ snmpwalk -v2c -cplebeian 10.200.1.10 ISIS-MIB::isisCircType
    ISIS-MIB::isisCircType.0.1 = INTEGER: ptToPt(2)
    ISIS-MIB::isisCircType.0.25 = INTEGER: ptToPt(2)
    ISIS-MIB::isisCircType.0.26 = INTEGER: ptToPt(2)
    ISIS-MIB::isisCircType.2.4 = INTEGER: ptToPt(2)
    ISIS-MIB::isisCircType.2.7 = INTEGER: ptToPt(2)
    ISIS-MIB::isisCircType.2.12 = INTEGER: ptToPt(2)
    ISIS-MIB::isisCircType.2.19 = INTEGER: ptToPt(2)
    $ snmpwalk -v2c -cplebeian 10.200.1.10 ISIS-MIB::isisISAdjState
    ISIS-MIB::isisISAdjState.0.25.1 = INTEGER: up(2)
    ISIS-MIB::isisISAdjState.0.26.1 = INTEGER: up(2)
    ISIS-MIB::isisISAdjState.2.19.1 = INTEGER: up(2)
    • wyang
      • Mar 2016
      • 93
      Would Zabbix experts please help me on this? Any advice would be much appreciated.
