How to disable multi items on one click
  • THUHV
    • Dec 2009
    • 28
    Dear my friends,
    My zabbix server has always detect alot of items that i don't want to monitor. If i disable one item by one click is very badly. Is there any way that i can check some of items and disable by one click? If yes, it's very great, and please let me know!
    Thanks you!
  • tchjts1
    • May 2008
    • 1605
    Use the filter.
    See this post: https://www.zabbix.com/forum/showthread.php?t=45034
    • THUHV
      • Dec 2009
      • 28
      Thank tchjts1,
      I know filter. But this is filter any items are Active or disable or something.
      Now, After i filter all of Active items, i want to change alot of items from Active to disable...because a lot of items that i don't want to monitor.
      Please help me.
      Thank you!
      • ingus.vilnis
        • Mar 2014
        • 908
        Please try the Mass update feature.
        Hope that helps!
        Best Regards,
        Ingus
        • THUHV
          • Dec 2009
          • 28
          Thanks Ingus,
          But i only want to disable alot of items in a host fast. I dont want to update a lot of host in a time.
          Thank you again!
          • tchjts1
            • May 2008
            • 1605
            Originally posted by THUHV
            Thank tchjts1,
            Please help me.
            Thank you!
            You can do that with the filter. Checkmark the items you want to disable or enable or whatever, then all the way down at the bottom left use the dropdown to select what you want to do and click on "Go". Done.
