We have multiple WAN interfaces with different bandwidth capacities/sizings. Is there a way that we could set the allocated bandwidth capacity (defined using macros) and create a trigger when the current bandwidth reaches 75% of allocated bandwidth for the respective interface?
I have searched for similar cases but wasn't able to relate to the above need. Appreciate any tip or direction to create triggers based on defined bandwidth capacity (instead of interface max capacity {$IF_UTIL_MAX}) on a single network device (cisco).
Thank you in advance.
