Help with Trigger for SNMP item
  • d0v1k
    • Nov 2019
    I have an SNMP item like below, i want to create a trigger for it. The output STRING is "Connected" or "Not Connected"
    How can i create a trigger to send notification when its Not Connected and recovery notification when connected?
    Name: Service Provider SMPP
    Type: SNMPv2 agent
    SNMP OID: 1.3.6.1.4.1.33355.1.1.3.6.3
    SNMP community: {$SNMP_COMMUNITY}
  • IPTC
    • Aug 2019
    • 9
    Hi d0v1k,
    you can create a trigger for that, as for the send notification you'll need to work with "actions"
    For the trigger you can have an expression similar to this:
    Problem expression: {Service Provider SMPP: "key".last()}=Not Connected
    Recovery expression: {Service Provider SMPP: "key".last()}=Connected
    Now for the notification part, it can depend, do you want to recieve an email or a text message? If you do you need to work with actions.
    In actions you choose the trigger, then you switch to Operations submenu, there you add a "New" Operation, in that menu you choose the users to recieve the notification or in case you want an email/text message you go to the "Send only to" option and choose between the options.
    For email, text message and Jabber you need to define those in Administration->Media Types
    Hope that helps you out.
    • d0v1k
      d0v1k commented
      Sorry for the late reply.
      This is the error i get when i add the trigger:
      Incorrect trigger expression. Check expression part starting from "{Ozeki: ozeki.SMPPUser.last()}=Not Connected".
