Low Level Discovery - need help
  • aigo15108
    • Oct 2019
    • 17
    I have a user-defined check on the agent, which from the host checks like this,
    $zabbix_get -s HOSTNAME -k check.disks
    "data":[
    {"{#MOUNT}":"/srv","{#SHORTMOUNTNAME}":"/srv"},
    {"{#MOUNT}":"/tmp","{#SHORTMOUNTNAME}":"/tmp"},
    {"{#MOUNT}":"/var","{#SHORTMOUNTNAME}":"/var"},
    Discovery rule
    Name: Check Disks on {HOST.NAME}
    Type: Zabbix agent (active)
    Key: check.disks
    Update Interval: 10s
    Item
    Name: Free disk space on {#MOUNT}(percentage)
    Key: vfs.fs.size[{#MOUNT},pfree]
    Type of information: Numeric (float)
    Units: %
    Waited for 2 hours, there is no latest data from HOSTNAME. So how does this caboodle work? Anyone?
  • aigo15108
    • Oct 2019
    • 17
    Originally posted by splitek
    Are you created Item? If so create item prototype not item.
    Thank you.
