Hello all,
In Zabbix 2.4 we can now check SSL Certificates for Hosts in Web Scenarios, thank you very much for that.
What I try to do now is to check for the SSL Certificate Expiry Days.
So I want to know how many days I have left on a certificate until it expires.
Then I want to add triggers some days before the certificate will expire.
In the past I have done this with an external script.
I was hoping this is now possible with some kind of an item but there is none.
Does anyone know howto do this with the new feature SSL Verify Peer?
