I have kind of problem related to subject. Simple I want to preserve historic data of statically monitored for example root fs volume monitoring data and move these data to newly created items using LLD.
On first if new template will not contain / volume items old template can be unlinked and after apply new template such items will be still present as untemplated. In the same time LLD which will generate vfs.fs.size[/,free] will fail because it will be conflict between untemplate item using the same key.
Theoretically it may be possible using SQL queries to assign the same itemid to new item created using LLD but this is only theory as long as LLD will be not able to create own items because it will be keys definition clash.
Someone have been doing such zabbix internal data migration or maybe prepared some kind of general approach or even piece of script which may be used on such scenario?
Regards
kloczek
Regards
kloczek
