Weblogic monitoring template (JMX). No data returned for some mbeans.
  • rindbaek
    • Nov 2019
    I am working on setting up a weblogic template. We use zabbix 4.4 with a java gateway 4.4.1 and connect to a weblogic 12.2.1.3.
    My problem is that i cant see data/attrubutes for all the mbeans. through zabbix. I see them fine in jconsole.
    I zabbix i can see the java.lang for instance the Garbeag collector. but i dont get data for data in the com.bea part.
    My garbage collector discovery rule is configured like this:
    key: jmx.discovery[beans,"*:type=GarbageCollector,name=*"]
    jmx endpoint: service:jmx:rmi:///jndi/iiop://{HOST.CONN}:{HOST.PORT}/weblogic.management.mbeanservers.domainruntime
    and i have an Item prototype like this:
    Name: GC {#JMXLOCATION} {#JMXNAME} CollectionCount
    Key: jmx[{#JMXOBJ},CollectionCount]
    Jmx endpoint: service:jmx:rmi:///jndi/iiop://{HOST.CONN}:{HOST.PORT}/weblogic.management.mbeanservers.domainruntime
    This works fine and i see the data.
    But im also interestet in things like the state of my managed servers (in the com.bea)...
    So i create a discovery rule for that
    key: jmx.discovery[beans,"*:type=Server,name=*"]
    Name: MS {#JMXLOCATION} {#JMXNAME} State
    Key: jmx[{#JMXOBJ},StartupMode]
    I dont get any data. for this and in the java gateway log i se this:
    2019-11-28 13:32:26.235 [pool-1-thread-2] DEBUG com.zabbix.gateway.ItemChecker - getting value for item 'jmx.discovery[beans,"*:type=Server,name=*"]'
    2019-11-28 13:32:26.239 [pool-1-thread-2] DEBUG com.zabbix.gateway.ItemChecker - received value '{"data":[]}' for item 'jmx.discovery[beans,"*:type=Server,name=*"]'
    This is one of the mbean's i try to hit...
  • Purnima Upadhyaya
    • Mar 2021
    Hi Rindbaek, were you able to figure out how to see data for managed server, I also trying same but no luck yet
