log monitor of block
  • marc55
    • Sep 2014
    • 18
    HI,
    I would like to monitor a block in log file, for instance
    I have this kind of entries in log file (on several lines)
    ERROR:this is a new error:ERROR
    DETAIL: description of this error
    other relevant informationETAIL
    HOST:myhost:HOST
    Is it possible using zabbix log monitoring to catch what we have between DETAIL when zabbix see ERROR
    I guess that we could use extended zabbix agent, but as it's log file, it's not easy to do that (must start at the last entry at next polling, or start at the begining if log file has been recreated etc ...)
    Thank's for your help
    Regards,
    Marc
  • jan.garaj
    • Jan 2010
    • 506
    POC:
    log[/path/to/file/file_name,<regexp>,,,,/1]
    regexp must to match information, which you need (ERROR.*DETAIL) - this can be big challenge.
    You don't need to care about last entry or rotation of log file - zabbix agent is prepared for these situations.
    Read manual:
    • marc55
      • Sep 2014
      • 18
      Hi
      Thank's for your answer but seems not working
      Here is my test
      I created a log file that contain following entries
      ERROR:detail descrition line1
      detail description line2:ERROR
      and I created a log item with following keys
      log[C:/ZABBIX_AGENT/log.txt,ERROR.*):ERROR,,,,\1]
      I got nothing
      So I created this new item
      log[C:/ZABBIX_AGENT/log.txt,ERROR.*),,,,\1]
      and I got "detail descrition line1" as output
      So I assume that it only analysed the first line which correctly corresponds to the pattern.
      Question, how can I analyse the full block (between ERROR tag) and not only one line?
      Regards,
      Marc
      • jan.garaj
        • Jan 2010
        • 506
        You need to write right regular expression. (ERROR.*DETAIL) was only proof of concept. You need to investigate right POSIX regular expression. Use some online tools for testing.
