Create graph from UserParameter with text output
  • jensborgenon
    • Nov 2019
    Hi Guys,
    I'm currenlty using zabbix version 4.2.1 and have the following question:
    I have a userparameter item which is configured to have text output. I've put a status indicator as first char in the output (0 for OK, 2 for NOK; see example below)
    OK -> "0 OVN_connection_failed - OK"
    NOK -> "2 OVN_connection_failed - ALARM!!"
    Currently I can only see the history like this:
    2019-11-29 17:18:35 0 OVN_connection_failed - OK
    2019-11-29 17:18:15 0 OVN_connection_failed - OK
    2019-11-29 17:18:05 0 OVN_connection_failed - OK
    Is there a way to show the first char of my output (the status indicator) in a Graph instead of the whole output in "History"?
    Thank you,
    Jens
  • Hamardaban
    • May 2019
    • 2714
    You can create dependent item ( https://www.zabbix.com/documentation...ependent_items)
    type - numeric. With preprocessing: type - regular expression , parameters - “^(\d)\s.*$”, output - “\1”
    And do what you want with this
    • jensborgenon
      • Nov 2019
      Hi Hamardaban,
      That works perfectly!
      Thank you.
