Change of syntax in 2.4 WTH
  • Grossx
    • Feb 2010
    So who came up with the great idea to change standard programming operators #,&,| to <>, and, or ?
    Does this mean that i have to manually reconfigure ALL my thousands of triggers in all my current templates after upgrade? Are you mad?
  • ingus.vilnis
    • Mar 2014
    • 908
    No, it is not that bad. The triggers are converted automatically at the upgrade.
    If I remember correct you could even import 2.2 templates to 2.4 without any changes in XML file. The operators are converted. Does not work when importing 2.4 -> 2.2 though.
    Best Regards,
    Ingus
    • Grossx
      • Feb 2010
      Oh, that's a relief. Thanks for the reply.
