Zabbix 2.4 Overview filter
  • killach
    • Jul 2012
    • 13
    Hi all,
    Just installed Zabbix 2.4 and get the ennoying filter menus just above the triggers in overview and I can live with that but when switching between screens it defaults to triggers that had or have a problem state. I have emails configured and I want for the Overview to be an Overview, to show every trigger. Is there any way to change it defaulting to triggers with problems to show all? I was meddling with overview.php and actually managed to do it but then I have problems applying any filters.
    Why change the overview in the first place?
    Is it possible or am I stuck with it if I stay with 2.4 version?
  • killach
    • Jul 2012
    • 13
    Anyone any ideas?
    • GOID
      • Oct 2014
      • 35
      Originally posted by killach
      Hi all,
      I found hardcode solution.
      in overview.php you can comment two strings and filter will be save our choice.
      PHP Code:
      //if (getRequest('show_triggers') != TRIGGERS_OPTION_ALL) {
      CProfile::update('web.overview.filter.show_triggers', getRequest('show_triggers'), PROFILE_TYPE_INT);
      REMEMBER: dev comment above this string
      // show triggers
      // when this filter is set to "All" it must not be remembered in the profiles because it may render the
      // whole page inaccessible on large installations.
      • ebonweaver
        • Feb 2013
        • 71
        Awesome, this works!
