I am trying to set up some MSSQL monitoring that includes LLD for both instances and databases. The scripts that I have (https://github.com/MantasTumenas/Zab...oft-SQL-Server) works when run from the local host in powershell, but when I issue a zabbix_get from the proxy server I am getting null values. Here's an example of what I am getting:
This is what I get when the script runs on the local machine:
But when I run zabbix_get from the proxy server I get the following:
Can anyone shed some light on my this might be happening? I've checked the log file and the call is being called correctly as far as I can tell.
And here is the script:
PS C:\Program Files\Zabbix> .\Scripts\Discovery.mssql.instancename.ps1
"data": [
"{#SQLINSTANCENAME}": "MSSQLSERVER",
"{#SQLINSTANCE}": "SQLServer",
"{#SQLINSTANCESERVICE}": "MSSQLSERVER"
zabbix_get -s mysqserverhost -k instances.mssql.discovery
"data": [
"{#SQLINSTANCENAME}": null,
"{#SQLINSTANCE}": "MSSQL$",
"{#SQLINSTANCESERVICE}": "MSSQL$"
# Query to get instance name.
$obj = [PSCustomObject] @{
data = @((get-itemproperty 'HKLM:\SOFTWARE\Microsoft\Microsoft SQL Server').InstalledInstances | % {
[PSCustomObject] @{
'{#SQLINSTANCENAME}' = $_
'{#SQLINSTANCE}' = if($_ -eq 'MSSQLSERVER') { "SQLServer" } else { "MSSQL`$$_" }
'{#SQLINSTANCESERVICE}' = if($_ -eq 'MSSQLSERVER') { "MSSQLSERVER" } else { "MSSQL`$$_" }
Write-Output $($obj | ConvertTo-Json)
