I have setup a active check using log[]. I've set it up on about 400 hosts, a hand full are giving file permission errors. However the file permission is 644 and if I sudo bash to zabbix user I can cat the file. Any ideas?
zabbix-agent-4.4.1-1.el7.x86_64
3340:20191202:195303.919 active check "log[/var/log/salt/minion,The Salt Master has rejected this minion's public key]" is not supported: Cannot open file "/var/log/salt/minion": [13] Permission denied
# ls -l /var/log/salt/minion
-rw-r--r--. 1 root root 25837 Dec 2 19:28 /var/log/salt/minion
root# sudo -H -u zabbix bash -c 'tail /var/log/salt/minion'
Creating home directory for zabbix.
.... DATA IS HERE ...
