Hello all -
I'm running zabbix 2.2.5. I'm using the default "Template OS Windows" template and the associated filesystem and network interface discovery. This functions as expected.
I set up a trigger to send me alerts when an item goes into "Not Supported" state. When I reboot my windows clients, I get a lot of triggers/alerts about discovered items becoming not supported, and then going back to the expected "supported" state a minute or two later. As a result, the trigger send a lot of emails. This is extremely annoying - I'm not understanding why this is happening.
My "keep lost resources period" is the default 30 days.
I guess I could change the trigger to not send emails & just show the alert in the web interface, but it seems like these triggers shouldn't be firing in the first place..?
Also, is there a way in the web interface to easily get a list of all the items that are currently in "unsupported" state? (IE:in the main "monitoring dashboard" screen you can see the NUMBER of unsupported items, but you cant click on that number to see the details in a single screen).
Thanks in advance!
Thanks in advance!
