Nginx monitor
  • Satur
    • Dec 2019
    Nginx monitor
    Hello!
    I am trying to monitor nginx service with this template https://www.zabbix.com/integrations/nginx
    But I am having problems getting values to Server using status page and all template values are empty. Tried both Agent and HTTP templates with no results.
    Both Agent and Get have version 4.4.3 and CentOS 7
    Following commands do not work
    zabbix_get -s 127.0.0.1 -k system.run["curl http://127.0.0.1/basic_status"]
    Returns
    curl: (7) Couldn't connect to server
    zabbix_get -s 127.0.0.1 -p 10050 -k web.page.get["localhost","basic_status","80"]
    Returns
    ZBX_NOTSUPPORTED: Cannot perform cURL request: Couldn't connect to server.
    Log
    23799:20191204:144827.860 Requested [web.page.get[localhost,basic_status,80]]
    23799:20191204:144827.869 Sending back [ZBX_NOTSUPPORTED: Cannot perform cURL request: Couldn't connect to server.]
    But calling command from command line or with zabbix user works fine
    su zabbix -s /bin/bash -c "curl http://localhost/basic_status"
    Both returns
    Active connections: 1
    server accepts handled requests
    1111 2222 3333
    Reading: 0 Writing: 2 Waiting: 3
    What could be the problem here for the zabbix_get commands to run successfully?
    Seems to be some server specific problem, because requesting google.com also does not work on this server while works fine on other servers with the same Agent version
    zabbix_get -s 127.0.0.1 -p 10050 -k web.page.get["google.com"]
    Returns
    Thank you!
  • Satur
    • Dec 2019
    Everything started working after disabling SELinux!
    Un liels paldies par noderīgo produktu!
