I have to display a third status "fault" on a map element(Type=Host) with a different icon than default or problem.
My idea:
Use maintenance icon as the fault status. If a trigger with the problem severity is on fault, the host goes automatically on maintenance and show the fault icon on the map.
Problem:
I didn't found a proper way to automatically go into maintenance, if a trigger with severity fault is triggered.
Question:
Is there maybe a other way to display a third icon for the severity fault?
If not, how do i automattically go from a trigger into maintenance?
My idea:
Problem:
Question:
