Partitioning zabbix database with Mariadb 5.5.60 + Zabbix 4.2
  • isantos
    • Jun 2019
    Good afternoon guys
    Can anybody help me ?
    When I run the "ALTER TABLE" command, I get the error below:
    ALTER TABLE `history_uint` PARTITION BY RANGE (clock) (PARTITION p2019_12_04 LESS THAN VALUES (UNIX_TIMESTAMP (" 2019-12-05 00:00:00 ")) ENGINE = InnoDB;
    ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '' at line 1
    I am using Centos 7 with zabbix 4.2 and Mariadb in version (mysql Ver 15.1 Distrib 5.5.60-MariaDB, for Linux (x86_64) using readline 5.1)
    Could you tell me where the mistake is?
  • walter
    • Sep 2017
    • 16
    You can try this,
    (PARTITION p2019_12_04 VALUES LESS THAN (UNIX_TIMESTAMP("2019-12-05 00:00:00")) ENGINE = InnoDB);
