PowerCLI Powershell ZBX_NOTSUPPORTED
  • zabbixx
    • Jul 2012
    • 71
    Hello am trieng to run a powershell script an a zabbix agent!
    but i get allways the "ZBX_NOTSUPPORTED"
    zabbix@lmv64-snp-01:~$ zabbix_get -s 192.168.1.10 -k system.run["powershell.exe  -File D:\source_dev\scripts\zabbix\get-CPU-by-pool.ps1",wait]
    ZBX_NOTSUPPORTED
    but if i do :
    zabbix@lmv64-snp-01:~$ zabbix_get -s 141.73.60.85 -k system.run["echo test",wait]
    test
    i get answer!
    waths wrong?
    my execution timeout
    zabbix@lmv64-snp-01:~$ cat /etc/zabbix/zabbix_server.conf | grep "Timeout*"
    ### Option: Timeout
    Timeout=30
    ### Option: TrapperTimeout
    TrapperTimeout=300
    pleas help to get this script working .
    reg. zabbixx
  • zabbixx
    • Jul 2012
    • 71
    if you have the same problem, you can try to adjust the zabbix CLIENT timeout time in the zabbix_client.conf!!
    in my sution it was not helpfuly, so i createt a windows task that runs every 5 minutes and write the values in to the text file.
    so you can just request the content of this file from the zabbixServer! is much faster then run and wate the script it self!
    the item refresh time value must be greater then the sheduled task interval in windows.
    if you have problems let me know!
    regard zabbix
