Hi
I want to upgrade zabbix server from 2.0.8 to 2.2.6 on CentOS 5
But I have a problem (there is no changes after upgrade), lets start from beginning:
My server:
php -v
PHP 5.4.33 (cli) (built: Sep 20 2014 16:31:22)
mysql -V
mysql Ver 14.14 Distrib 5.5.40, for Linux (x86_64) using readline 5.1
cat /etc/*release
CentOS release 5.10 (Final)
I have done below commands:
1. Stop Zabbix:
su - zabbix
sudo /etc/init.d/zabbix_server stop
sudo /etc/init.d/zabbix_agentd stop
2. Back up the existing Zabbix database
mkdir -p /home/zabbix/zabbix_upgrade/backup
cd /home/zabbix/zabbix_upgrade/backup
mysqldump -uroot -pzabbixadmin zabbix > zabbix.backup.sql
3. Back up configuration files, PHP files and zabbix binaries
in /home/zabbix/zabbix_upgrade/backup performed:
cp -rp /etc/zabbix .
cp -rp /etc/init.d/zabbix-* .
cp -rp /usr/sbin/zabbix* .
cp -rp /usr/local/sbin/zabbix* .
cp -rp /usr/bin/zabbix* .
cp -rp /usr/local/bin/zabbix* .
4. Installation
4.1 I've downloaded zabbix-2.2.6.tar.gz and copy to /home/zabbix/zabbix_upgrade
4.2 tar xzvf zabbix-2.2.6.tar.gz
4.3 cd zabbix-2.2.6
4.4 ./configure --prefix=/usr --with-mysql --with-net-snmp --with-libcurl --enable-server --enable-agent
[root@sip3 zabbix-2.2.6]# ./configure --prefix=/usr --with-mysql --with-net-snmp --with-libcurl --enable-server --enable-agent
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
configure: Configuring Zabbix 2.2.6
checking whether make sets $(MAKE)... (cached) yes
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
<cut>
checking for ICONV support... yes
checking for mkdir -p candidate... ok (/bin/mkdir -p)
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating database/Makefile
config.status: creating misc/Makefile
config.status: creating src/Makefile
<cut>
* Now run 'make install' *
* Thank you for using Zabbix! *
* <http://www.zabbix.com> *
4.5 make
[root@sip3 zabbix-2.2.6]# make
Making all in src
make[1]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src'
Making all in libs
make[2]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src/libs'
Making all in zbxcrypto
make[3]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src/libs/zbxcrypto'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src/libs/zbxcrypto'
Making all in zbxcommon
make[3]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src/libs/zbxcommon'
<cut>
Making all in upgrades
make[1]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/upgrades'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/upgrades'
make[1]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6'
make[1]: Nothing to be done for `all-am'.
make[1]: Leaving directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6'
4.6 make install
[root@sip3 zabbix-2.2.6]# make install
Making install in src
Making install in libs
Making install in zbxcrypto
make[4]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src/libs/zbxcrypto'
make[4]: Nothing to be done for `install-exec-am'.
make[4]: Nothing to be done for `install-data-am'.
make[4]: Leaving directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/src/libs/zbxcrypto'
Making install in zbxcommon
<cut>
Making install in upgrades
make[2]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/upgrades'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6/upgrades'
make[2]: Entering directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6'
make[2]: Leaving directory `/home/zabbix/zabbix_upgrade/zabbix-2.2.6'
4.7 check the zabbix version:
[root@sip3 zabbix-2.2.6]# zabbix_server --help
Zabbix server v2.0.8 (revision 38017) (21 August 2013)
<cut>
As I see there is no changes after upgrade, should I do something more or the procedure of upgrade is incorrect?
Please help
My server:
php -v
mysql -V
cat /etc/*release
1. Stop Zabbix:
su - zabbix
4. Installation
4.3 cd zabbix-2.2.6
<cut>
<cut>
4.5 make
Making all in src
Making all in libs
<cut>
4.6 make install
<cut>
<cut>
Please help
