Hi,guys,I want to disabled snmp bulk in zabbix 2.2.6,when I apply the patch using "patch -p0 < no-snmp-bulk-in-2.2.6.patch",the effect is not obvious.So,I want to change the source code to disabled snmp bulk.
In 2.2.6 source code check_snmp.c and function zbx_snmp_walk like:
bulk = (ITEM_TYPE_SNMPv1 == item->type ? 0 : 1);
pdu = snmp_pdu_create(0 == bulk ? SNMP_MSG_GETNEXT : SNMP_MSG_GETBULK)
I just want to set bulk=0,whether this can disable SNMP bulk requests globally?And in 2.2.7 version daemon improvements also say: EnableSNMPBulk configuration parameter should be set to 0 in order to disable SNMP bulk requests globally.
Thanks in advance.
Thanks in advance.
