Install issues with 1.1b5
  • brwatters
    • Feb 2005
    Hello all,
    I am seeing some issues with v1.1b5 install,
    I think the config and compile went without issue, all the database build was no problem .. However after getting all of this in place and installing the web gui and logging in without issue I note in the server status area that it says the server is not running (no in red) however the server is running as shown below ..
    zabbix 14822 0.0 0.0 4284 1316 ? S 19:03 0:00 ./zabbix_server
    zabbix 14855 0.0 0.0 4276 1300 ? S 19:03 0:00 ./zabbix_server
    zabbix 14886 0.0 0.0 4284 1320 ? S 19:03 0:00 ./zabbix_server
    zabbix 14948 0.0 0.0 4484 1916 ? S 19:03 0:00 ./zabbix_server
    zabbix 15042 0.0 0.0 4276 1300 ? S 19:03 0:00 ./zabbix_server
    zabbix 15104 0.0 0.0 4276 1300 ? S 19:03 0:00 ./zabbix_server
    zabbix 15139 0.0 0.0 4276 1300 ? S 19:03 0:00 ./zabbix_server
    And here is a SNIP of the log file in debug level ..
    014948:20050218:225036 In DBnum_rows
    014948:20050218:225036 Result of DBnum_rows [1]
    014948:20050218:225036 Nextcheck:-1 Time:1108792236
    014948:20050218:225036 Sleeping for 60 seconds
    014886:20050218:225037 In create_host_file()
    014886:20050218:225037 Executing query:select distinct h.ip from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1108792237)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and i.status=0 and h.useip=1
    014886:20050218:225037 In DBnum_rows
    014886:20050218:225037 Executing query:select distinct h.host from hosts h,items i where i.hostid=h.hostid and (h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1108792237)) and (i.key_='icmpping' or i.key_='icmppingsec') and i.type=3 and i.status=0 and h.useip=0
    014886:20050218:225037 In do_ping()
    014855:20050218:225049 Executing query:select distinct f.itemid,f.functionid,f.parameter from functions f, items i,hosts h where h.hostid=i.hostid and ((h.status=0 and h.available!=2) or (h.status=0 and h.available=2 and h.disable_until<1108792249)) and i.itemid=f.itemid and f.function='nodata' and i.lastclock+f.parameter<=1108792249 and i.status=0 and i.type=2 and (f.lastvalue<>1 or f.lastvalue is NULL)
    014855:20050218:225049 In DBnum_rows
    014822:20050218:225049 Executing query:select a.alertid,a.mediatypeid,a.sendto,a.subject,a.messa ge,a.status,a.retries,mt.mediatypeid,mt.type,mt.de scription,mt.smtp_server,mt.smtp_helo,mt.smtp_emai l,mt.exec_path from alerts a,media_type mt where a.status=0 and a.retries<3 and a.mediatypeid=mt.mediatypeid order by a.clock
    014822:20050218:225049 In DBnum_rows
    And one more bit of info with logging set at level 3
    000616:20050218:230833 Starting zabbix_server...
    000677:20050218:230833 #server 1 started [Alerter]
    000704:20050218:230833 server #2 started [nodata() calculator]
    000737:20050218:230833 server #3 started [ICMP pinger]
    000868:20050218:230833 server #5 started [Trapper]
    000931:20050218:230833 server #6 started [Trapper]
    001060:20050218:230833 server #7 started [Trapper]
    000800:20050218:230833 server #4 started [Sucker. SNMP:ON]
    Anyone able to tell me if I am in the right direction ?? .. this is on a RH9 box ..
    Brian
