Monitoring KVM Hypervisor (QEMU/Libvirt/Virsh) - Via Zabbix Agent
  • SiriX
    • Dec 2019
    I've installed Zabbix 4.4-3 and configured it up, based on the zabbix.com site saying your software supports monitoring KVM.
    And if you follow this link: https://www.zabbix.com/integrations/kvm it shows up as an integration.
    However, so far, I've not had any luck with using Virbix with Zabbix 4.4-3.
    While yes I can install the plugin, and I'm able to install the template file.
    But I get no data back and appear to have errors showing up in different places, some around JSON in the Zabbix UI, but then also seeing issues to do with permissions, and im thinking maybe it's trying to write something somewhere without permission?
    Any help from someone who's actually implemented proper KVM monitoring with Zabbix (At the hypervisor level) would be much appreciated!
    Thanks!
  • lptarik
    • Oct 2021
    • 33
    Did you find anything? I am trying to monitor Ovirt
    • RoyK
      • Jan 2016
      • 22
      Seems to me, the one on https://github.com/sergiotocalini/virbix is really outdated and not usable today. It'd be nice to have something newer, though.
      • tuanchu
        • May 2024
        Has anyone implemented it yet, I have the same problem
